Author Topic: 9.0 to 9.1.98 Discrepancy in droplets (non-caustics)  (Read 4239 times)
Offline DMerz III
  • KeyShot Beta
  • David Merz the Third
    • @MerzTheThird
« on: February 12, 2020, 08:17:15 am »
Originally posted this in the KS 9.1 Beta thread - but that has been locked.
So reposting here with more tests and more info.
I would classify this as a bug since it was something that was working a certain way - and now is broken.
Windows 10 Pro
Tested on multiple PCs - all showing the same results
Xeon processors
Can is a 'metal' shader with a 'plastic' label. Stripe is opacity cut out of the label to the 'can'. It's not related to drops on a label as I've tried turning label off making can itself plastic.
This is a major problem for us since the workflow is established and we've gone with these exact settings for 1000s of renders using KS8
Switching to GPU does look 'better' here but is not an option right now as our equipment is all CPU pipeline.
Offline Justin A
  • KeyShot Support
  • Jr. Member
Re: 9.0 to 9.1.98 Discrepancy in droplets (non-caustics)
« Reply #1 on: February 13, 2020, 09:15:41 am »
Hello Dmerz,
I have been trying to reproduce the issue you are having without success.
Would you be able to share the KSP so that I can do a bit more troubleshooting?
or at least a scene that has the problem in it?
Thanks,
Justin
Luxion support
Offline DMerz III
  • KeyShot Beta
    • @MerzTheThird
« Reply #2 on: February 13, 2020, 01:40:24 pm »
Just made a new scene - Created a closed cylinder - added closed spheres scattered all over - the spheres are nested into the surface of the cylinder.
Getting same result.
Do note - the Realtime View does differ from the Render Output - In the realtime view the drops will be darkened (also a new behavior in 9.1 from 9.0 & 8.0) - but in the rendered output (shown) - it is completely blacked out.
Sending the .ksp of this to you via your wetransfer.
Offline Justin A
  • KeyShot Support
  • Jr. Member
« Reply #3 on: February 14, 2020, 09:06:59 am »
Thank you for the scene,
I am currently taking a look at this and with collaboration from my development team I hope to have some answers for you shortly.
Thanks again
Offline DMerz III
  • KeyShot Beta
    • @MerzTheThird
« Reply #4 on: February 17, 2020, 09:09:58 am »
Thanks, Justin. The team and I are eagerly awaiting.
Hopefully, it can be resolved soon! We know it was working with 9.0!
