Author Topic: Glass Jagged Refraction Issue  (Read 746 times)
Offline raglo
« on: June 18, 2020, 03:28:27 am »
I'm getting these weird jagged lines with the stock glass material in Keyshot 9. The screenshot clear shows the problem. In case it's not clear on the screenshot, the jagged edges appear when looking at the back of the cone through the front. I've also attached the bip file. I hope someone can help me troubleshoot.
Details:
Keyshot 9.3.14
macOS 10.15.5
MacBook Pro 16,1 (2.3 i9, 5500m 4gb, 16 gb RAM)
Offline raglo
Re: Glass Jagged Refraction Issue
« Reply #1 on: June 20, 2020, 11:50:58 pm »
This really urgent. Can someone please help?
Offline Finema
« Reply #2 on: June 21, 2020, 01:17:07 am »
It's your model that's not correct. Redraw it and export it properly. That's what I did. I'm attaching the .bip.
Offline raglo
« Reply #3 on: June 21, 2020, 01:36:19 am »
Hey thanks a lot. Could you please explain what you mean by redraw and export? I'm using Fusion360 with the keyshot export plugin.
Offline Finema
« Reply #4 on: June 21, 2020, 02:31:58 am »
what are the export parameters with the plugin?
Offline Berube
« Reply #5 on: June 30, 2020, 01:17:43 pm »
Hi there,
May wanna try to export the model separately. IGES or any other nurbs format will assure a smooth parametric curved look.
STEP, FBX and obj may triangulate the model using polygons.
-Berube
Online TGS808
« Reply #6 on: June 30, 2020, 02:05:40 pm »
IGES or any other nurbs format will assure a smooth parametric curved look. STEP, FBX and obj may triangulate the model using polygons.
Like IGES, STEP is also a NURBS format. Of course, everything that gets brought into KS gets turned in to a triangulated mesh in the end, but STEP is will retain NURBS info if you check the box on import.
