Author Topic: Anisotropic Radial Reflections "Centred on Part"?  (Read 641 times)
Offline lilliput
« on: June 26, 2020, 06:13:34 am »
Hey pretty new keyshot user so forgive me if this question has a simple solution I haven't thought of.
I am rendering an assembly involving numerous parts (way more parts than I want to do one by one) which I want to have a metallic Anisotropic radial brushed finish. I have so far done this by applying a "Brushed (Radial)" bump texture which is "Centered on Part". This seems perfect allowing all components I apply with this material to link to one and other but have the brushed bump texture centred on each individual instance.
When I came to controlling the reflections (provided by the Anisotropic material type) adding the "Roughness X" and "Roughness Y" I selected the Radial Mode but it no longer gives me a way to centre on part instead I only have the option to "Position Texture" which isn't unique to each component its the reflection centre for all components this material is applied to :(
Is there a way around this allowing me to keep the reflections centred on each part without giving every part its own material and making it a nightmare to manage and make alterations down the line?
Offline lilliput
Re: Anisotropic Radial Reflections "Centred on Part"?
« Reply #1 on: July 03, 2020, 07:25:24 am »
So nobody else has had this problem??
Offline Eugen Fetsch
« Reply #2 on: July 06, 2020, 12:22:44 am »
Try using "Part" instead of "Model" mapping in the texture properties.
« Reply #3 on: July 06, 2020, 12:23:59 am »
If it doesn't help. Then you would need to unlink the material and adjust it seprately for the objects where the texture is off.
