Author Topic: Tips on improving animation render times using motion blur?  (Read 3520 times)
Offline hayth
« on: February 03, 2021, 02:15:32 am »
Running two RTX Titans, and rendering a sequence with motion blur on is 10 times slower!  Any tips on workarounds?  Nvidia control panel settings?  Anything would be appreciated!
Offline designgestalt
Re: Tips on improving animation render times using motion blur?
« Reply #1 on: February 03, 2021, 08:43:06 am »
honestly, the best workaround would be to add the motion blur in post !
saves you a ton of rendertime and looks decent enough!
In most cases it is absolutely sufficient.
Render a small sequence with motion blur and one with MB added in AE and compare.
Depending on how often you need it, I would suggest RealSmart Motion Blur for AE. It costs some money but is well worth it!
Even in an ideal world I would most likely render without DOF and Motion Blur as you have more freedom if you (or your client ;) )want to change something afterwards...
best regards
designgestalt
Offline hayth
« Reply #2 on: February 14, 2021, 02:36:37 pm »
Thanks for the tip!
Offline mattjgerard
« Reply #3 on: February 16, 2021, 02:36:24 pm »
I will second RealSmart for motion blur. almost looks better than KS motion blur. For speedy stuff that's the way to do it.
