Thumbnail doesn't work well on Windows10 Explorer
Started by Higuchi, February 28, 2021, 10:16:45 PM
Higuchi
Hi there,
I've been facing strange phenomenon about thumbnail since version10.0 was launched. Recently, I changed my PC environment from Case1 to Case2 to Case3. In the end, on case3 I can't see any thumbnails as you can see attached image. I think it's not special case, since I got same consequence depending on each case every time.
Case1.
Thumbnail doesn't work well :'(
- installed software: Keyshot9 and 10
- default opening software: Keyshot9
Case2.
Thumbnail works well :)
- default opening software: Keyshot10
Case3.
- installed software: Keyshot10
Is the error caused by Keyshot or Windows10?
Hope someone gives me quick solution, or tell me if you are facing same problem!
Best,
Eugen Fetsch
Don't know where it comes from. To fix this issue I ended up deleting everything KeyShot related from the regestry. Maybe a local installation (instead "For all users") may help.  ::)
Here's a fix listed in support portal: https://luxion.freshdesk.com/support/solutions/articles/60000670645-thumbnails-missing-from-bip-file
The default opening version is always the last installed version driven by the registry:
Computer\HKEY_CURRENT_USER\SOFTWARE\Luxion > KeyShotVersion
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Luxion > KeyShotVersion
Higuchi
#3
Thank you for the reply, but I couldn't make it.
I did option1 guided on the link above, namely I downloaded "Full installer" and executed re-install without uninstall. Unfortunately, the situation was not improved.
Should I try option2?
Higuchi
#4
Hi administrator,
How would the thing end up? After that, while I've done uninstall and reinstall Keyshot10, the condition was not improved. If you suggest me option2 "You can register the Preview handler found in the KeyShot bin folder. Open Command Prompt in administrator mode.", could you tell me more details? What does "the Preview handler" mean? As far as I see on bin folder on my computer, there are not likely to be related one.
Francisco
We also have these steps that you can try and do to see if they help. If you don't feel comfortable with messing in the registry you can ask an IT member to help you with these steps.
https://luxion.freshdesk.com/support/solutions/articles/60000690417-missing-bip-thumbnail-advance-troubleshooting
Higuchi
Thank you for letting me know.
Actually, I've tried it with the support of local Keyshot agent, but my problem was not improved. Now, I put the environment back on the Case2, namely I reinstalled Keyshot9 to get thumbnail again. But, it's just tentative treatment.
alexaben
#7
Don't have the foggiest idea where it comes from. To fix this issue I wound up erasing all that KeyShot related from the regestry.
