Gem material turn back after being applied
Started by NineAmulets, March 11, 2021, 07:30:03 PM
NineAmulets
I have a KS 10 HD ZBrush bridge. When I try to apply the ruby material to a gem model it turns black. Not sure why...other gems don't present the same results
Hello NineAmulets.
Are there any changes with scale, units that effects the transparency distance?
CheerEO
NineAmulets
#2
No. When I import other objects from ZBrush and apply that material, the same happens. However when I click on performance mode, it looks more like a ruby, but if I render it I'll get the black stone again :(
HaroldL
NineAmulets
Nope, no difference at all. I've changed all the light settings but didn't see any changes at all.
makhacks34
Hello
NineAmulets
just edit gemstone ruby material and after that increase the transparency distance 2 mm - 5 mm. error will solve .
NineAmulets
Sorry. You were right I was wrong. I enter the numeric value and it changed the stone color! I was using the slide and that didn't do anything.
