Can I have the map scale with the model? Each time the map position is adjusted,
Started by syn0288, March 25, 2022, 07:51:25 PM
syn0288
Can I have the map scale with the model? Each time the map position is adjusted, once the model is scaled, the map has to be adjusted again
Erik Williams
If I understand your question correctly, you should be able to coordinate map and model scaling using the guide at
https://manual.keyshot.com/keyshot11/manual/materials/material-graph/material-graph-nodes/utility-node-types/mapping-2d/
If this does not work for you or I've misunderstood the situation, please let me know.
Med Venlig Hilsen / Best Regards,
Erik Williams
Customer Support Specialist
syn0288
I mean, after scaling the size of the model, the map doesn't match the size of the model. You need to resize the map. Can the map scale with the model
Quote from: syn0288 on April 07, 2022, 10:47:51 PM
The only way to do this is with UV mapping. That ties the textures to the actual polys on the model.
