Does KeyShot have emissive materials?
Started by hdstudio, May 14, 2010, 06:55:00 AM
hdstudio
If so, is this a way to create additional lighting in a scene?  Can you control the amount of light that is emitted?
If you need that you will need to use an HDRI at certain exposure that you map to an object. v2 will have an actual emissive material.
You realize that you can rotate the environment, change the height, as well as adjust brightness and gamma to get the desired lighting effects?
Thomas
