1 Hour
1 Day
1 Week
1 Month
Forever
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
Home
Help
Search
Login
Register
KeyShot Forum
Technical discussions
Data Import
SketchUp
sketchupivy plugin - strange leaves effect
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: sketchupivy plugin - strange leaves effect (Read 9211 times)
tibet
Newbie
Total likes: 0
SketchUp 2013 user
on:
April 15, 2012, 10:53:36 am »
hi,
is anyone experienced the same effect with sketchupivy plugin as me, and knows how to fix the problem with leaves?
any share is very much appreciated. the leaves are png files in SU plugin folder.
thanks!
Last Edit: April 15, 2012, 10:57:12 am by tibet
Logged
Guest
Re: sketchupivy plugin - strange leaves effect
Reply #1 on:
April 16, 2012, 07:08:26 am »
Can you share this example? Also, what result does the direct import deliver? I think that it may not recognize the alpha map of the texture.
Logged
tibet
Newbie
Total likes: 0
SketchUp 2013 user
Reply #2 on:
April 18, 2012, 03:32:59 am »
hi thanks for a quick answer.
a similar model has been created, and attached below.
thanks for any tips to make people happy :-)
cheers!
Logged
Guest
Reply #3 on:
April 18, 2012, 07:09:37 am »
Can you send the sketchup model?
Logged
tibet
Newbie
Total likes: 0
SketchUp 2013 user
Reply #4 on:
April 23, 2012, 10:22:36 am »
hi,
sorry for late reply, of course i will upload my model.
thanks for valuable tips.
Logged
Guest
Reply #5 on:
April 24, 2012, 09:35:13 am »
Thanks for sharing -we will take a look
Logged
hugo
Jr. Member
Total likes: 0
Reply #6 on:
March 03, 2014, 12:54:33 pm »
Quote from: Thomas Teger on April 24, 2012, 09:35:13 am
WoW!........ Still no solution to this problem. Anyone can try Thomas Luft's Ivy Editor
http://ivy-generator.com/
The SketchUp Ruby which produced this IVY is based on the texture mapping that Thomas implemented.
Most 3d rendering programs have no problem using image based textures, and then have them render correctly.
Logged
thomasteger
Guest
Reply #7 on:
March 04, 2014, 10:25:48 am »
Double click on the material, and check "use diffuse map alpha".
Ideally this should be done automatically. We will get it fixed. But at least this will solve this for now.
Logged
Print
Pages: [
1
Go Up
« previous
next »
KeyShot Forum
Data Import
SketchUp
