sketchupivy plugin - strange leaves effect
Started by tibet, April 15, 2012, 10:53:36 AM
tibet
hi,
is anyone experienced the same effect with sketchupivy plugin as me, and knows how to fix the problem with leaves?
any share is very much appreciated. the leaves are png files in SU plugin folder.
thanks!
Can you share this example? Also, what result does the direct import deliver? I think that it may not recognize the alpha map of the texture.
tibet
hi thanks for a quick answer.
a similar model has been created, and attached below.
thanks for any tips to make people happy :-)
cheers!
tibet
hi,
sorry for late reply, of course i will upload my model.
thanks for valuable tips.
hugo
Quote from: Thomas Teger on April 24, 2012, 09:35:13 AM
Thanks for sharing -we will take a look
WoW!........ Still no solution to this problem. Anyone can try Thomas Luft's Ivy Editor
http://ivy-generator.com/ The  SketchUp Ruby which produced this IVY is based on the texture mapping that Thomas implemented.
Most 3d rendering programs have no problem using image based textures, and then have them render correctly.
thomasteger
Double click on the material, and check "use diffuse map alpha".
Ideally this should be done automatically. We will get it fixed. But at least this will solve this for now.
