Fiat 500... Rebuild on
Started by tsunami, June 08, 2012, 03:41:48 PM
tsunami
Here, after a long working, and following all suggestions about backplate, some new renders shots...
Regards
EGON
To me the cars don't blend into the background. Look pasted on.
tsunami
Quote from: EGON on June 08, 2012, 04:08:25 PM
That's better Egon?..maybe before too much postwork..
still pasted on?
Regards
The last image looks nice-  perhaps move the blue car over to the left a bit?  It does not read as a car, but more like a blue halo.  Or, for this image, just hide it?
EGON
Looks better. Now get rid of the blue car. Tip. When I have a scene that's not blending. Convert to B&W. Will always look better. Then ask yourself why. Then try it again in color. Brite sunlight is tough.
CAClark
Part of the reason I think they guys are seeing a slight non blending issue is that the shadows under the car should be pretty much black, and the ground itself shouldn't be truly visible due to the darkness. At the moment it's very ambient under the cars.
I'd agree with egon about taking out the car that is almost totally obscured in the last render.
The alignments look good to me.
Cheers!
tsunami
Quote from: CAClark on June 09, 2012, 03:09:06 AM
Cheers!
Clark, it's hard to get real black shadows under the car, on keyshot..i tried many times..that's could be fine using postwork with ps, but i would get the goal only with keyshot environment light...so some tricks about it?
(well i think i will get off the blue car or i will move in a new position)
Regards
voxelman
It seems that the cars are lit with an overcast sky rather than the blue sky in the scene. I think I expect more glint and sharper and brighter reflections.
PhilippeV8
Look at the trailers in the background, and particuarly at their shadow, it's off to the left and well defined.  Use an environement that cast real shadow.  There's a topic which lists the environements you can use.  I'll try to find it.
PhilippeV8
tsunami
Quote from: PhilippeV8 on June 10, 2012, 01:25:51 PM
http://keyshot.com/forum/index.php/topic,2515.msg10364.html#msg10364
there you go ..
Thanks as always Philippe, i got a look at the thread, ...but i don't know how to get or where to buy those hdri..i have not same light environment on my collection...
PhilippeV8
I think HDRI Urban should be default .. you should have it, no ?
tsunami
Quote from: PhilippeV8 on June 10, 2012, 11:52:45 PM
Yes sure, i have that one "urban" on my keyshot environment default, but i meant california Desert hdri, (i read was with hypershot default, so i can't have them )..
regards
PhilippeV8
Ok, so use the urban HDRI.  Play with brightness & contrast to tune the shadows.
1 thing you can't do (yet) is rotate the environement around the other axis to match the suns inclination though.  I worked round this by editing out the sun in this HDRI and replace it with a pin in the HDRI editor.
tsunami
Quote from: PhilippeV8 on June 11, 2012, 12:28:33 AM
Philippe i'm using that urban environment, and u are right..shadows are much better, also if now i have some problems with paint metal flake result...on the render image :o ..but i will post asap.
(i tried also with an other cad model , maserati gt, but result is not that good as i thought)..
Regards
