A few ideas
Started by Robert V., September 30, 2012, 03:06:52 PM
Robert V.
Hi keyshot team.
Keyshot is already perfect as it is, but I also know that the keyshot team is always looking for new features which could make keyshot an even better choice for customers.
So here are a few ideas:
  • New material type: Fur. (handy for almost every carpet, towel etc. does not need to be "hair")
  • New material attribute: displacement maps (doesn't need explanation I guess)
  • New light: beam... maybe by using a fog-effect.
  • Tagging system for environments and backplates. These tags can be "extracted" from the file name, or users can add them themselves. This could also give advice, for example: one searches for desert road, and the correct selection of HDRI's appear. After selecting the environment, keyshot will automatically suggest fitting backplates.
  • Motion blur for spinning objects (like wheels)
  • Measure tool (ruler). and 1:1 conversion of dimensions from imported model. 1cm in (for example) solidworks is equal to 1cm in keyshot. So if I move the object in keyshot 4 units, it moves 4 cm (or the selected unit like mm, cm, m, inches, etc.)
  • Part/grid snapping, like "mates" within solidworks. For example I have build a train, and I want more waggons, I can duplicate the model and snap them together.
  • GPU support
I realise that some have been mentioned before, but I wanted to make sure my list has everything I would love to see.
Thank you for your suggestions. I can confirm that out of these suggestions GPU support will not happen. There is no benefit in going this route.
dav3punk
Quote from: thomasteger on October 01, 2012, 07:00:57 AM
Well, since this was a long time ago, GPU support seems pretty mandatory as the tech is pretty prominent now and is the future... ;)
mafrieger
instead of GPU or in addition, it woud be great to get the most out of current CPU's features.
See "take advantage of processor's feature sets for speeding up rendering"
https://www.keyshot.com/forum/index.php?topic=14201.0
