Snail
Started by Seghier, October 21, 2012, 03:34:23 PM
Seghier
Hello , i make shell with rhino than convert it to base mesh with tsplines to export it to 3dsmax
and i create the base mesh of snail  with blender , i use mudbox to add details and painting; finally Keyshot for rendering and sketchbook
tsunami
Superb!!! the most beautifull render i saw here!!!!!!!
Seghier
Seghier
Screenshots : Rhino; blender; mudbox; 3dsmax
Seghier
update
TheCrazySwede
Great texturing! The specularity adds a lot of realism!
Seghier
Thanks TheCrazySwede  :)
i will modify the displacement texture of snail , and learn how animate it
Seghier
new model
PhilippeV8
This looks a lot better !
The "foot" of the snail looks much more real with that wider "skirt".
Suggestion from what I see comparing to real photos: tilt the house a bit forward .. the edge of the house can "bite" a bit into it's back.  This should "connect" them more together.
The glossy-slimy-wet look does seem real, but comparing to real photo's, it's mostly the underneath that has the slime .. no ?
Seghier
Hello Philippe and thank you for you nice reply :)
about the house and the back i see photos sometimes like what you say and in other photos no connection between them
and the wet i think it is real in rainy day but i will try to reduce glossiness
PhilippeV8
hmmz .. it probably depends on how the picture is taken, no ?  Use of flash and/or angle etc.
Either way, though I don't like the beast, the render is great already :)
Seghier
Many thanks Phillippe :)
yes the angle of camera make difference , the same shell with the same material have difference reflection in the last two images
Shooter
Hey Seghier,
here's two my own imgs, maybe it will help you to get better results  :)
All the best,
Voya
Seghier
Thank you Voya , very beautiful photos
i will use them in the nest snail :)
Shooter
Im truly glad you like them, its just too bad i didnt take more photos of that snail on the road surface..... if only he went other way i could get the other side of his shell but it is what it is :) Use them however you like !
