Dispersion
Started by Johnjoti, June 28, 2010, 07:34:20 PM
Ed
There's a LOT of lens flare in that animation giving it sparkle.  Lens flare is an artifact that is not going to show in a render.  Not saying a lens flare effect would be a bad idea for an optional filter in KeyShot, but the flare is created by the lens.
If you take a static screen shot of the animation, discount the lens flare, it's on par with previously posted KeyShot examples.
If those KeyShot examples were animated on a turntable, you would see much the same, except for the lens flare.
Ed
Johnjoti
Quote from: Johnjoti on September 10, 2010, 02:56:47 PM
Сonvulse!!!!!!   ;D :D ;D
sorry  :D
Quote from: Ed on July 01, 2010, 08:54:04 PM
and yes I work with small diamonds, but not 2 carat :)
Ed
Ed does not work with large stones. I guess he can't seen
"The tune" goes something like this
http://www.coldiamond.com/cross-of-light-diamond.html
try and do it in keyshot!!! and show us
QuoteABBE, HDRI, reduce pixel filtering...
LOL
I don't think that's good enough.
Keyshot diamond mat is underdeveloped!!
It stopped in the development with Hypershot 2008 :( :( :(
Johnjoti
Ed
You think only of oneself, about wedding rings with spark diamond...
Quotesparkle, lens flare, animation...
Of course. Why do you need it
Johnjoti
#48
Quote from: 583 post_id=1162 date=1277780129Ideally it shall have a gradient of pure gray with highlight contrast as the main color + bright multicolored sparks of the classic color wheel + slightly reflection of the environment
That's about it.
I have a sneaking suspicion that the Keyshot going to succeed  ;)
Johnjoti
#49
Hi all
KeyShot added new material gem in the 2.1
It differs from the old (dielectric) ?
I did not notice any difference ((((((((
In what, essentially, lies the difference?
KeyShot
It is easier to understand. The old solid glass was used for both liquids and gems, and it made more sense to made dedicated materials for gem, glass, and liquids. The dielectric material is indeed the old solid glass.
Johnjoti
I used black and white HDRi
Abbe number 10
Ray bounces 30
Pixel filter size 1
Nothing changed
The brown (dirty) color is still here
KeyShot
If you can send your model and hdri to support@luxion.com then we can take a look at it.
Johnjoti
I send you model and HDRi
but diamond should look like this:
alternative soft
or
HDRi
Johnjoti
Johnjoti
#55
Am I being a bore?
Ok I will not press the point  :'(
JeffM
John,
Here's an example of the high contrast and richly colored dispersion type diamonds, like you had posted above.
20 ABBE
10 ABBE
For this effect you just need to keep your realtime gamma low and adjust the ABBE. Also adjust the brightness and gamma of the environment itself for further control.
