I have a model of a complete agricultural machine which needs to be rendered showing our plastic hood parts. The complete assembly is so heavy, opening it in master rep is nearly impossible, so I made a simplified representation to open. All components I want to show are in master state, all others are excluded from this representation.
Not a single model gets exported to Keyshot 4 using the plugin, only camera orientations. All models are solids, no quilts.
Is this a known issue, does the plugin require the assembly to be openend in master representation before it can export a simplified representation?
Rendering it with Keyshot 3 isn't a option due to the already known issue of the assembly regeneration (see other topic). The files we received from the client start regenerating with issues causing Pro/E to crash.
Regards,
Dominick
