Standard Glass
Started by jmfit, July 05, 2010, 08:48:37 PM
jmfit
Hi all-
I've imported this cone from SW and applied the standard glass material to it. It's rendering with some jagged edges on the inside of the cone.  Is there a correct setting to get the edges to appear smoother?
Thanks--
Joe
David
check the image quality / tessellation in SW?
Tools / options / Document Properties / image quality. increase the values to achieve a smoother model.
jmfit
David-
Thanks--
I had this peice in an assembly and cranked up the image quality of the individual part to the max. It still was looked the same.
Figured out you can't adjust the assembly file quality. Saved the entire assembly as a single part with the quality set all the way up. Now it looks much better!!
Thanks again!!
Joe
