Author Topic: decal color not coming through  (Read 5747 times)
Offline J.B.
« on: March 19, 2013, 06:49:19 pm »
Hi This is my first time trying to put on a decal for a customer and not just for fun. I applied the image (.png) to the material as a bumpmap and tried all the settings. I can get it positioned correctly, but not to be anything but black and white. (the colors won't come through) I need these colors to come through for it to look like the actual unit is turned on and "displaying" this image. What settings do I have incorrect?
Thanks in advance for any and all help.
I am using Keyshot HD V1.9 64 bit.
Here is the image with color....
Here is my screenshot...
« Last Edit: March 20, 2013, 08:03:06 am by J.B. »
Offline PhilippeV8
Re: decal color not coming through
« Reply #1 on: March 20, 2013, 12:09:50 am »
I can't see your images (got a nasty web-filtere here at work) ... If you upload them to the forum directly I can see them all.
Either way, so you aply a decal to the bump-map ??  Why ?
You should go to the "label" tab (next to the texture tab) and put your decal in there.
Offline Esben Oxholm
« Reply #2 on: March 20, 2013, 06:40:09 am »
You should, as PhilippeV8 states, apply it as a label and not a bumbmap.
Check out this tutorial: http://www.youtube.com/v/gn6b0nHkvPo
« Last Edit: March 22, 2013, 03:39:19 am by Esben Oxholm »
Offline J.B.
« Reply #3 on: March 20, 2013, 08:00:02 am »
Remember, I am using Keyshot V1.9 (see my first post)
I do not see any Label tab in this version.
Philippe - I uploaded the images now. Hopefully you can see them now.
Thank you.
« Last Edit: March 20, 2013, 08:04:16 am by J.B. »
  • Guest
« Reply #4 on: March 20, 2013, 09:57:26 am »
You will need to apply the graphic as a texture.
And why are you still on 1.9? It is time to upgrade!
Offline J.B.
« Reply #5 on: March 20, 2013, 11:19:54 am »
Well, Version 1.9 still does all I need it to do. Sure, the newer versions can do more, but what I need and what I want are two different things. This year I invested in a 3D scanning endeavor and so maybe next year will be the year for the Keyshot upgrade? (unless of course things go exceedingky well this year and upgrading comes early ;) )
Offline J.B.
« Reply #6 on: March 20, 2013, 01:08:40 pm »
Thank you! Got it to work as a texture.
even in version 1.9 this software still rocks.
  • Guest
« Reply #7 on: March 20, 2013, 02:23:17 pm »
Great to hear. Thanks!
