Bead blasted Stainless Steel
Started by Michael1974, April 15, 2013, 03:33:36 AM
Michael1974
Does anyone have this material as a file that they would be willing to post here for use?
I can't believe that Keyshot doesn't have this as standard - or have I missed it? (Only recently started using)
Despot
It's very easy to do after looking at reference images.
Use the 'Steel' or 'Stainless Steel' preset and change the diffuse colour chip to suit, then apply a bump map that will give you the desired look.
I will post an image soon, although unfortunately I cannot share the bump map as it is not mine to pass on - if I get time I will create one from scratch
J
Despot
Matte and Gloss versions...
Also as I understand it there are many different types of blast patterns and finishes
J
Michael1974
Many thanks
We use a fine bead blast on stainless steel to prouduce a smooth satin finish
Despot
Well, not sure if that's anywhere near...  :-\
Perhaps if you post an image of what you require, give me some visual reference
J
