Network Render Queue
Started by jamesg91, May 21, 2013, 07:53:51 AM
jamesg91
It would be nice if the UI in the queue window is easier to use and had more control. For example, if I have renders that have more urgent priority than other renders that are already in the queue it would be useful to be able to highlight the ones I want and simply drag them up above the others, instead of having to select each one individually and 'move up' the queue, which is pretty laborious and time consuming when you have urgent requests and priorities change.
I also think it would be nice to pause certain renders in the window (which I guess is just a variant of the above), i.e. certain renders require more urgent priority, so pausing certain renders higher up in the queue will force bypass so that these can take precedence of the network.
One more thing - can we increase the preview window size? So that when you drag the control menu at the bottom up the screen, the preview window increases also. This would be pretty useful if your screen is on a big desk and you have to lean forward to view the tiny preview!
