Measure glass
Started by Georg Malm, July 19, 2013, 03:54:06 PM
Georg Malm
Please help.
Need to put measure bumping on measure tube.
How to make it appear properly?
It is only normal cylinder.
Can't get it appear..
Despot
#1
You are using a .PNG with transparency as a bump map, KS apparently does not like that...
Convert your .PNG to a .JPG and all will be fine... I also gaussian blurred the map by 1.3 pixels and you get a nice smooth bevelled bump.
Here is what I ended up with, had to set the mapping up from scratch as it was missing from your file as you didn't save a KS package
Set the bump to .65 and it looked ok to me, hope this helps - if you need my file let me know
J
You can use a png with transparency as bump map without any problems.
Despot
#3
I'd like to point out Thomas, that with greatest of respect, that's not strictly true...
Some tests to follow...
Despot
OK... here are the bump maps used in these tests :
A 400x400 JPG with a solid white background and a .PNG with 24bit transparency (white knocked out)
Despot
The first screenshot is rendered using the JPG with Bump Height set to 1
The second screenshot is rendered using the PNG with Bump Height set to 1
The third screenshot is rendered using the PNG with the Bump Height ramped up to 10
As you can see Thomas, using a transparent .PNG means you've got to increase the Bump Scale by a factor of 10 to get the same result as the .JPG
N.B. On the JPG render, the square seam appears because of the quick and dirty mapping type used, if the cube was UV mapped this wouldn't show
J
edwardo
People..... Get 'crazy bump' and output a normal map! The results are so much better, and you don't get the square seam edge. It's adds 3 minutes to your work flow, but well worth it.
Ed
Despot
Hey Edwardo - I use Crazy Bump all the time, but more for displacement maps if I don't paint them myself...
But to be honest, I avoid bump maps like the plague, I prefer to model detail - I only tend to use them for scratch and damage work but at an almost non-existent bump height...
I was simply pointing something out here  ;)
J
edwardo
Yea, modelling every detail is the way to do it, if possible. Crazy bump is great for free though
Metal Master - We will look into it.
Georg Malm
Quote from: Thomas Teger on July 20, 2013, 09:05:46 AM
Fair enough, Thomas.
But could you share a solution for my case.
All you need to do is increase the bump height when using the PNG as Metal Master suggested.
jhiker
Quote from: The Metal Master on July 20, 2013, 08:33:29 AM
J
I got it working using the png as a label but there's no way I could use it as a bump map and get it to look anything like your excellent image.
I'd certainly appreciate a look at your BIP file if you're happy to share it. I'd like to learn how to achieve that effect.
Many thanks.
Despot
No problem Jhiker - but I cannot share the HDR image used in those renders unfortunately
So if what you're after is the 'lighting' part of the render, you're out of luck ;)
J
jhiker
Thanks, but I'm not interested in the lighting - more the application of the bump map.
Want me to PM you?
