Author Topic: Best Renders I have ever seen!  (Read 50924 times)
Offline gbaillot
Re: Best Renders I have ever seen!
« Reply #15 on: August 15, 2013, 05:27:15 am »
Sorry for my English  :-[ . Here is the test I just realized on KS 4.0 with patches on Photoshops CS 6.
Duration=20 min
Offline diamond
« Reply #16 on: August 15, 2013, 06:20:26 am »
Duration=20 min
Looks good. Can you share what you did? (Settings? HDR? Background? lighting?).
Offline diamond
« Reply #17 on: August 15, 2013, 06:22:38 am »
i am not into this kind of renders but here is my 5 min setup contribution  ;D
interactive render...still noisy..as it needed to run longer but there you go
M
Very clean. Metal looks good diamonds not so great. Can you share what you did? (Settings? HDR? Background? lighting?). Thanks again.
Offline DriesV
  • Administrator
  • Total likes: 29
« Reply #18 on: August 15, 2013, 07:49:45 am »
Here's my attempt.
There's no dispersion in the gems though...
With 24 ray bounces KeyShot becomes VERY unresponsive if I enable dispersion (abbe above 0) for the gems. :-\
Anyone else getting this too?
« Last Edit: August 15, 2013, 12:23:22 pm by DriesV »
Offline Ed
« Reply #19 on: August 15, 2013, 07:58:30 am »
Dries,
My 12 core PC hangs up if I go beyond 10 ray bounces on the diamond material.  On previous KS versions I could go 24 no problem.  Also my diamond material with KS 4.3.15 is missing the ABBE setting.  Looks like the Gloss setting is affecting dispersion, but in a weird way.  Perhaps I need to to a fresh install rather than an update.
Ed
  • Guest
« Reply #20 on: August 15, 2013, 08:03:53 am »
There is a bug, and you will need to switch back to "roughness" in the preferences. This has been fixed in 4.2.
We will look into the performance issues.
Offline Ed
« Reply #21 on: August 15, 2013, 08:38:39 am »
Here's my take on the diamond ring.  Diamond may be a little dark because I can't go above 10 ray bounces when using the diamond material (see posting below).
Ed
« Last Edit: August 15, 2013, 08:58:02 am by Ed »
Offline evilmaul
« Reply #22 on: August 15, 2013, 08:55:08 am »
in my case i did nothing special..thats why i ve spent only 5 min on it :)
left shaders the same, white background , added ground plane and used  Light Tent White Open 3 2k2.hdz  env...lowering the brightness a bit
thats all
PS: I agree with the ray bounces settings from >12 the computer just dies silently  ;D
« Last Edit: August 15, 2013, 08:57:50 am by evilmaul »
Offline jhiker
« Reply #23 on: August 15, 2013, 09:03:12 am »
I'm a novice at jewellery but here's my two penn'orth..!
Offline jhiker
« Reply #24 on: August 15, 2013, 09:05:13 am »
Ah - should've resized it...  ::)
Offline DriesV
  • Administrator
  • Total likes: 29
« Reply #25 on: August 15, 2013, 09:05:42 am »
Here's the same ring, but this time with white color gems and dispersion.
« Last Edit: August 15, 2013, 12:24:15 pm by DriesV »
Offline diamond
« Reply #26 on: August 15, 2013, 09:51:35 am »
Thats looks great! Are you willing to let us in one what you did. Did you post edit? Is that a custom HDR?
Offline DriesV
  • Administrator
  • Total likes: 29
« Reply #27 on: August 15, 2013, 10:05:42 am »
Straight out of KeyShot (no post work).
Started from a black HDRI and added pins in the HDR Editor.
Offline Robb63
« Reply #28 on: August 15, 2013, 10:17:39 am »
Here's a 5 min setup version I worked on while I was eating lunch.
Offline diamond
« Reply #29 on: August 15, 2013, 12:02:53 pm »
I dont think that you would see this render in a magazine, It looks like a five minute render. Does anyone have time to show us how Keyshot can replicate the same render I posted at the beginning of this post? Does anyone know about BunkSpeed?
