Best Renders I have ever seen!
Started by diamond, August 14, 2013, 10:35:29 AM
gbaillot
Sorry for my English  :-[ . Here is the test I just realized on KS 4.0 with patches on Photoshops CS 6.
Duration=20 min
diamond
Quote from: gbaillot on August 15, 2013, 05:27:15 AM
Duration=20 min
Looks good. Can you share what you did? (Settings? HDR? Background? lighting?).
diamond
Quote from: evilmaul on August 14, 2013, 06:01:02 PM
i am not into this kind of renders but here is my 5 min setup contribution  ;D
interactive render...still noisy..as it needed to run longer but there you go
M
Very clean. Metal looks good diamonds not so great. Can you share what you did? (Settings? HDR? Background? lighting?). Thanks again.
DriesV
#18
Here's my attempt.
There's no dispersion in the gems though...
With 24 ray bounces KeyShot becomes VERY unresponsive if I enable dispersion (abbe above 0) for the gems. :-\
Anyone else getting this too?
Ed
Dries,
My 12 core PC hangs up if I go beyond 10 ray bounces on the diamond material.  On previous KS versions I could go 24 no problem.  Also my diamond material with KS 4.3.15 is missing the ABBE setting.  Looks like the Gloss setting is affecting dispersion, but in a weird way.  Perhaps I need to to a fresh install rather than an update.
Ed
There is a bug, and you will need to switch back to "roughness" in the preferences. This has been fixed in 4.2.
We will look into the performance issues.
Ed
#21
Here's my take on the diamond ring.  Diamond may be a little dark because I can't go above 10 ray bounces when using the diamond material (see posting below).
Ed
evilmaul
#22
in my case i did nothing special..thats why i ve spent only 5 min on it :)
left shaders the same, white background , added ground plane and used  Light Tent White Open 3 2k2.hdz  env...lowering the brightness a bit
thats all
PS: I agree with the ray bounces settings from >12 the computer just dies silently  ;D
jhiker
I'm a novice at jewellery but here's my two penn'orth..!
jhiker
DriesV
#25
Here's the same ring, but this time with white color gems and dispersion.
diamond
Quote from: DriesV on August 15, 2013, 09:05:42 AM
Thats looks great! Are you willing to let us in one what you did. Did you post edit? Is that a custom HDR?
DriesV
Straight out of KeyShot (no post work).
Started from a black HDRI and added pins in the HDR Editor.
Robb63
Here's a 5 min setup version I worked on while I was eating lunch.
diamond
Quote from: Robb63 on August 15, 2013, 10:17:39 AM
I dont think that you would see this render in a magazine, It looks like a five minute render. Does anyone have time to show us how Keyshot can replicate the same render I posted at the beginning of this post? Does anyone know about BunkSpeed?
