Author Topic: In a big ocean  (Read 5428 times)
Offline Noozbe
In a big ocean
« on: October 25, 2013, 06:45:07 am »
Hi all !
First please excuse my english, i'm french.
I have a boat project and i try to integrate it in his environment : the ocean.
I have try lot of things but it's not very convaincant.
Do you know how can i make realistic ocean ?
I have make one with Solidworks (A volume with waves in his surface) and apply translucid material and bump texture but it's not realistic.
Someone to help me ?
Bye !
Thomas.
thomasteger
  • Guest
Re: In a big ocean
« Reply #1 on: October 25, 2013, 07:27:17 am »
Use a ground plane from the EDIT menu and edit the material. Change to liquid or glass, change the color, and apply a wave texture as a bump map. That should get you started.
Offline Noozbe
Re: In a big ocean
« Reply #2 on: October 26, 2013, 12:02:38 pm »
Thank you for your answer.
It's a basic solution but i need to make realistic water, with splash.
Do you know if it's possible to use a frame of RealFlow for export it to Keyshot after and make the render ?
Regards.
Thomas.
thomasteger
  • Guest
Re: In a big ocean
« Reply #3 on: October 27, 2013, 06:22:44 am »
As long as you export as OBJ from RealFlow you can import your RF geometry into KeyShot.
