Author Topic: 18k Gold Ring with Stones  (Read 3704 times)
Offline Saskia
« on: August 09, 2010, 03:40:25 pm »
just jewelry
  • Guest
Re: 18k Gold Ring with Stones
« Reply #1 on: August 10, 2010, 02:57:36 pm »
Nice - make sure you select "snap to ground" - your ring is intersecting the ground plane.
Thomas
Offline Saskia
« Reply #2 on: August 12, 2010, 04:59:24 am »
snap to ground - done
Thank You, Thomas
  • Guest
« Reply #3 on: August 13, 2010, 06:07:07 am »
Ahh - sweet. Now do the same as I suggested in the other post. A little bit of roughness on the material to make it look more real.
Offline Saskia
« Reply #4 on: August 15, 2010, 01:06:16 pm »
just a tad bit of roughness - done.
I got a strange problem:
couldn't open the bip file in KeyShot 2, opened it in KeyShot 1.9
and there is no (check "sharp glossy reflections" in the environment tab).
After all: learning by doing changed to learning by Thomas. Thanks for your support.
PS. did the same in the other post
  • Guest
« Reply #5 on: August 15, 2010, 01:52:11 pm »
Hmm - strange why it wouldn't open in KeyShot 2. Correct  -1 . 9 doesn't have this.
But make sure you double click on the material and increase roughness to 0.05 or less. Then you will see the effect.
