Adding material to just a surface
Started by DougDR, January 07, 2014, 01:49:56 AM
DougDR
I would like to know how to add a color or material to just a surface and not a hole part?
NDenekamp
To do so, you must isolate the surface in your modelling software either by:
- giving it a separate colour
- moving the surface to a separate layer
- separating the surface from the rest of the part
The option that works easiest for you will depend of the modelling software you use and the file type you import into KeyShot
n
And if you need to, you can create a special surface in your native CAD using a "split line" (SolidWorks) or a similar tool in other apps.  Then color the resulting surface.
