Author Topic: The zoom function  (Read 8245 times)
Offline bowen192
The zoom function
« on: May 01, 2014, 02:20:46 am »
I'm having great difficulties with the zoom function:
1 I can add a zoom animation, but if I start adding other cameras and zooms, the zoom seems to be disregarded from the animation timeline.  There appears to be no option to put it back.
2 You cannot zoom on a particular point.
Any tips?
Offline TpwUK
Re: The zoom function
« Reply #1 on: May 01, 2014, 02:39:33 am »
Hi Bowen, this is being worked on in version 5 too, but i am not sure if you will be able to zoom to a specific point
Offline bowen192
« Reply #2 on: May 01, 2014, 02:51:56 am »
Am I missing something then?
If I am animating, surely there is a way to zoom in and out of more than one place?
Also, can you orbit around more than one axis?
Offline TpwUK
« Reply #3 on: May 01, 2014, 03:34:23 am »
Quote
There is indeed, but not in a fashion of a camera path curve, so you would have a camera start position, zoom in or out, do an orbit of n degrees and zoom in again. You can stack sequences too, such as a 5 second orbit, inclination and zoom. KS is just somewhat modular in its approach to animation so some animations at present have to be done as render passes or as a queue.
Quote
Yes, stack the orbits on the same timeline as mentioned above. :)
Quote
I don't know about you, but i have been for years  ;D
Offline bowen192
« Reply #4 on: May 09, 2014, 06:24:49 am »
Thanks for your help, but I'm still massively confused about the orbit function.
I just want to do a 360 degree orbit around the object x axis, but I can only get Keyshot to do it on the y axis.
Offline TpwUK
« Reply #5 on: May 09, 2014, 08:04:00 am »
For Y axis use inclination instead of orbit
Offline bowen192
« Reply #6 on: May 11, 2014, 11:44:41 pm »
 ::) You can't see the wood for the trees sometimes.
Cheers, Martin.
