Author Topic: Color gradient on Glass, etc.  (Read 15156 times)
Offline gustavozepeda
« on: June 09, 2014, 04:07:47 pm »
Is it possible to make a gradient when choosing Glass as a material?
I'm aiming to be able to produce a gradient like the following examples on glass:
Also I want to achieve from a solid color to transparent, is it possible?
Offline Rex
Re: Color gradient on Glass, etc.
« Reply #1 on: June 10, 2014, 12:02:28 pm »
KeyShot 5 provides a Color Gradient procedural texture type. Try using the "Glass" material in combination with the procedural Color Gradient color map. You can also create your own custom color gradients and use them as traditional color texture maps.
Offline jhiker
« Reply #2 on: June 11, 2014, 05:55:29 am »
Very nice! How do you do that.
My attempts lack the gradient and have sharp colour transitions. Could you share a *.bip or a package?
Many thanks
thomasteger
  • Guest
« Reply #3 on: June 11, 2014, 08:00:19 am »
Jeff - you need to adjust the scale in the color gradient editor. I think you need to increase it in order to get a smooth transition.
Offline Rex
« Reply #4 on: June 11, 2014, 10:14:49 am »
If you import using "Keep Original" size the color gradient scale should be optimized to fit your part. Try increasing the scale for a smoother transition, remember you can always type in a value larger than the slider allows. Also, the larger the difference in Location values the smoother the gradient.
Offline jhiker
« Reply #5 on: June 12, 2014, 01:58:43 am »
Ah - many thanks!  ;)
« Reply #6 on: June 14, 2014, 11:30:31 am »
Thank you so much for the help Rex; and Thomas for the tips!  :)
