Author Topic: Lable transparency I got black instead of transparent  (Read 3839 times)
Offline dparcell87
« on: August 12, 2014, 09:09:21 pm »
Hello, realize there is a similar topic on this and I still cannot figure out why everytime I want to import my PNG into keyshot which is a logo that I want to just show up as white,     I get a black background which is not what I need.   Just need to slap this white logo onto the dark colored 3d model .      And yes I do have the setting in PS to   8bit.      I attached the file and any help is appreciated. Thanks
Offline Robb63
Re: Lable transparency I got black instead of transparent
« Reply #1 on: August 13, 2014, 03:41:46 am »
When I'm creating mine, I typically use the export for web setting and use 24 bit. It works great for me.
Offline m2tts
« Reply #2 on: August 13, 2014, 04:51:07 am »
Make sure your image is saved in RGB format and that the png is just the white logo with no background. This will then save as a png with an alpha channel which Keyshot will use.
Offline dparcell87
« Reply #3 on: August 13, 2014, 10:31:48 am »
Yep that was what I was doing wrong I had it set to greyscale instead of RGB . works fine now.  Hate it when lil mundane details like that can slow down you workflow. thanks guys
