Author Topic: Rifle metal material  (Read 4889 times)
Offline patobek
« on: December 11, 2014, 10:49:35 am »
Hello guys :)
Pretty new here :)
My question is if there is any material or any way to make a material which looks similar to rifle metal without having to texture the actual rifle?
This is a model I finished these days and rendered with KS and I want to apply a more realistic looking material to it if possible :)
Thanks.
http://i.imgur.com/kv7bk9z.jpg
« Last Edit: December 11, 2014, 10:51:38 am by patobek »
Offline richardfunnell
Re: Rifle metal material
« Reply #1 on: December 11, 2014, 12:25:50 pm »
Hi Patobek,
Can you show us an example of the texture you're trying to achieve?
I don't have a rifle handy ;)
Offline patobek
« Reply #2 on: December 11, 2014, 09:42:41 pm »
« Last Edit: December 12, 2014, 04:56:44 am by Thomas Teger »
« Reply #3 on: December 12, 2014, 08:54:05 am »
Here's my quick attempt at that kind of material. I made quick part in NX to recreate similar geometry.
Starting with a metal material, I added a procedural bump texture, then adjusted the scale and bump height to get the textured effect.
Next, I used the procedural color curvature to get a slightly different material color on the rounded edges (which were added in NX) giving a bit more depth to the material color.
Lastly I added a little roughness under the base material properties to help scatter the reflections a bit more, and used a standard environment to light it.
How does this work for you? KSP attached.
Offline patobek
« Reply #4 on: December 13, 2014, 01:38:59 am »
Well I think its look better but its still rendering :)
We will se :)
Thanks for the mat.
