Author Topic: 2 bump textures on a tube...  (Read 2855 times)
Offline Finema
« on: January 16, 2015, 11:39:33 pm »
I'm new on Keyshot and i need to put 2 bump text on a same object.
I've a tube and i would like to place a text on the facing cylinder and an other bump text on the top.
On C4D, i can use multiple textures on a same model.
What's the way to do that on keyshot 5 ?
I know I can map multiple labels but textures ?
Must i duplicate or separate object or create skins to map it ?
« Last Edit: January 18, 2015, 09:23:51 pm by Finema »
Offline Rex
Re: 2 bump textures on a tube...
« Reply #1 on: January 19, 2015, 02:05:11 pm »
Finema,
Welcome to KeyShot! For now you can only apply 1 bump per material. I suggest you separate the surfaces of the cylinder so you can apply a different bump texture to each.
Rex
Offline Finema
« Reply #2 on: January 19, 2015, 07:28:30 pm »
Thanks Rex.
Offline Arn
« Reply #3 on: June 07, 2015, 03:42:28 am »
Since it is not possible to stack multiple bump maps, is it possible to export a procedurally generated bump map? That would allow manually adding the two together.
