Hi!
I have a problem importing data from creo 3 to keyshot 5. I just takes forever to import large assemblies and creo just takes up all my memory when i try to import geometry to keyshot.
It used to work fine with previous versions of creo and wildfire 5, but since i have updated to newer plugins (because i got creo 3) it just doesn't work as it should. I still have an older version of plugin for wf5 and for small parts it imports almost instantly and for large assemblies (like 4 gb and more) it does it under a minute. But with newer versions it takes about a minute for only a more complex part!
Is there any way to download previous versions of the plugins so i could try if the problem is really in plugins? I am not sure if there is an older version for creo3, but for creo2 would also work. Because now the only option for me is to import geometry from wf5, but most of our clients have already switched to a newer versions of creo.
Thanks!!
