Fail to import rhino file to keyshot
Started by pp, March 17, 2015, 07:08:31 AM
How to slove the problem?
yes
0 (0%)
no
0 (0%)
Total Members Voted: 0
pp
Hi, I am new to keyshot.When I try to import rhino file to keyshot. A box pop up and said"**doesn't not contain 3d geometry .Inside Rhino,please select View/Shaded prior to saving it."What does it means?How to solve it?
If you have KeyShot Pro then use the "Import NURBs" option when importing the model. If not, then you need  to set Rhino to be shaded view in the perspective view port, that will then generate render mesh data that KS can use.
rajsingh
#2
"///D/design/001.3dm"does not contain 3d geometry.
inside rhino,please select view/shaded piror to saving it.
for additional help please contact support@luxion.com???
1. open your file in keyshot
2. select IMPORT NURBS DATA  and click this option.
3. open your file successfully
