Poll
How to slove the problem?
yes
0 (0%)
no
0 (0%)
Total Members Voted: 0
Author Topic: Fail to import rhino file to keyshot  (Read 9961 times)
Offline pp
« on: March 17, 2015, 07:08:31 am »
Hi, I am new to keyshot.When I try to import rhino file to keyshot. A box pop up and said"**doesn't not contain 3d geometry .Inside Rhino,please select View/Shaded prior to saving it."What does it means?How to solve it?
Offline TpwUK
Re: Fail to import rhino file to keyshot
« Reply #1 on: March 17, 2015, 09:12:19 am »
If you have KeyShot Pro then use the "Import NURBs" option when importing the model. If not, then you need  to set Rhino to be shaded view in the perspective view port, that will then generate render mesh data that KS can use.
Offline rajsingh
Re: Fail to import rhino file to keyshot?
« Reply #2 on: November 18, 2015, 11:08:40 pm »
"///D/design/001.3dm"does not contain 3d geometry.
inside rhino,please select view/shaded piror to saving it.
for additional help please contact [email protected]???
1. open your file in keyshot
2. select IMPORT NURBS DATA  and click this option.
3. open your file successfully
« Last Edit: November 18, 2015, 11:13:46 pm by rajsingh »
