2 different bump maps to the same object?
Started by Zvi, May 20, 2016, 06:12:02 AM
Zvi
Can I use 2 different bump maps to the same object?
Finema
Hi
In Material graph > use Utilities >add Bump
See my screenshot
Esben Oxholm
Yup, if you have access to the material graph you can.
Just open up the material graph, add a bump add  node (right-click > utilities > bump add) and connect it to the bump input on your material and add your bumpmaps to the 'bump-add-node'-inputs. See attached. Hope it helps.
Esben Oxholm
