Author Topic: Remove ends of cylinder label  (Read 4125 times)
Offline Yabusa
« on: April 19, 2020, 09:53:00 am »
Is there a way to remove the flat ends of a cylindrical label?
The can has a rounded bottom, so the label is covering the inside as well
Offline Don Cheke
  • Jr. Member
  • Total likes: 6
  • Provider of Comprehensive TurboCAD Tutorials
    • Textual Creations
Re: Remove ends of cylinder label
« Reply #1 on: April 19, 2020, 11:29:41 am »
Does splitting surface not work for you, where you can then just add a different material on the bottom?
Offline Don Cheke
  • Jr. Member
  • Total likes: 6
    • Textual Creations
« Reply #2 on: April 19, 2020, 11:46:31 am »
Or add a separate surface in your modeling program and assign different material.
Offline Yabusa
« Reply #3 on: April 19, 2020, 11:53:37 am »
That would work, thanks for the suggestion
Offline INNEO_MWo
  • Total likes: 84
« Reply #4 on: April 21, 2020, 01:40:41 pm »
Use a color fade node as a clipping mask in the opacity channel of the label material. Or split the surfs.
