Author Topic: from 3DSMAX to Keyshot  (Read 4080 times)
Offline Higuchi
« on: May 01, 2021, 03:22:44 am »
Hi there,
I want to import 3DSMAX data containing material data, if possible.
Would it be possible if I use .obj or .fbx? Or, should be another extension?
I'm glad if you would explain how to proceed.
Thank you,
Offline DerekCicero
Re: from 3DSMAX to Keyshot
« Reply #1 on: May 07, 2021, 10:07:19 am »
I would use the plugin for best results:
KeyShot for 3ds Max Plugin
Supported Features
The KeyShot for 3ds Max plugin supports these features:
  • Parts retain materials and layers
  • Objects retain material names
  • Support for hair (curves)
  • LiveLinking (update model inside KeyShot)
  • Support for part and camera animations (requires KeyShot Pro)
  • Export of rigged and deformable animations (requires KeyShot Pro)
Offline Lenio
« Reply #2 on: August 22, 2021, 05:11:30 am »
I can't seem to find any discussion around 3DS Max plugin for Mac computers...does it exist, or is it Windows only?
Thanks!
Offline TGS808
« Reply #3 on: August 22, 2021, 07:04:09 am »
Thanks!
3DS Max is Windows only software. Always has been. There is no Mac version of the KS plug-in because there’s nothing for it to plug into.
Offline Lenio
« Reply #4 on: August 23, 2021, 05:43:50 am »
Makes sense -- my situation is that I do not model, I only use Keyshot to render. I wanted to make use of purchased model that in 3DS included all of the materials and such, but since I can't access that on the import, I would have to create materials for hundreds of objects within the model. Oh well, now I know.
Offline Marcelo Aguiar
« Reply #5 on: August 27, 2021, 06:34:37 pm »
Hey guys,
I'm definitely going to try that plug-in (is it compatible with KS 7?.... ), but I export from 3DS Max to KS all the time, and it works great.
I model using Multi sub-object materials and assign material IDs. Standard materials.
I export the model in FBX.
In KS I choose "assign materials from library" and "retain materials".
Works every time ;)
