Moving pivot point
Started by rossco, March 30, 2012, 12:58:51 AM
rossco
Hi.
I'm really struggling to get the pivot point moved the correct position to allow parts to move on the correct axis.  As far as I can see the only way to move the pivot point is to relate it to another part.  Is there a way to manually move a part's main axis so that it's centre of movement can be adjusted?
Right now, you can't move the pivot point manually.
rainycat
Has there been any development on this issue?
rfollett
Hello
Please can you help me. I have just watched your tutorial on animation and I have a question.
I have created pivot geometry in my rhino model so I can rotate parts. This pivot points will be invisable
BUT if I move the pivot point and then try to use it again later my object does not pivot around the new location of my pivot point?
It seems to pivot around original location of my pivot point.
Many thanks
