Author Topic: Objects inside a glass material object are black?  (Read 19315 times)
Offline Adar
« on: June 20, 2013, 07:23:07 am »
Hey guys !
I am encountering a weird problem which I didn't find an answer to anywhere on this forum.
For some reason when I use a dielectric material  the objects inside it turn black.
I tried upping the rays in the render settings but to no avail.
Some material colors are in fact slightly visible but in most cases it's just black as if there's a weird strong shadow that doesn't affect reflections over the inner objects.
Anyone knows why?
Thanks !
Offline jhiker
Re: Objects inside a glass material object are black?
« Reply #1 on: June 20, 2013, 07:34:04 am »
Have you got 'Global illumination' switched on...?
http://www.keyshot.com/keyshot4/manual/index.html
Offline Adar
« Reply #2 on: June 20, 2013, 05:59:13 pm »
Thanks for the.reply,
looking at the render settings I see I have 1 in global illumination and I also tried upping it to 5 though I can't see any difference.
Offline DriesV
  • Administrator
  • Total likes: 83
« Reply #3 on: June 20, 2013, 11:38:51 pm »
What happens when you switch your glass object's material from 'dielectric' to 'glass' (Two-sided checked)?
Offline PhilippeV8
« Reply #4 on: June 21, 2013, 12:40:42 am »
How much ray bounces do you have set up ?  It might be too low ?
Offline jhiker
« Reply #5 on: June 21, 2013, 01:00:38 am »
Global illumination is either on or off - checked or not checked - you can't put a number in there.
Check again.
  • Guest
« Reply #6 on: June 21, 2013, 05:50:53 am »
It is in the "Settings" tab of the Project window.
Offline Adar
« Reply #7 on: June 22, 2013, 11:39:22 pm »
Hey guys,
thanks so much for the replies !
I did need to turn on Global Illumination in the settings tab, for some reason I missed the advanced drop down menu and now it works.
Thanks for all the help !
