Author Topic: Texture electronic cable  (Read 7190 times)
Offline Skampus
« on: December 01, 2015, 07:24:58 am »
Hi everybody,
I need a short advise. I try to texture a cable. It has to be two colours going along the cable not twisted as you can regard at the screenshot.
I try a few ways without success ..now I´m blocked :P
Has someone the ultimate idea.
Offline TpwUK
Re: Texture electronic cable
« Reply #1 on: December 01, 2015, 05:10:49 pm »
Map a gradient type procedural material using cylinder as the mapping type ?
Offline Skampus
« Reply #2 on: December 02, 2015, 01:47:24 am »
Thanks Martin for that
Done ..the result is not that I hoped for. I add another Screen from a real cable. So it should lool like. Any idea is still welcome  :D
Offline TpwUK
« Reply #3 on: December 02, 2015, 05:02:05 am »
I just tried it too and got unexpected results. What file format is your model in ? I tried 3DM
Offline Skampus
« Reply #4 on: December 02, 2015, 05:07:30 am »
It is an Import from Creo .prt
Offline TpwUK
« Reply #5 on: December 02, 2015, 06:08:06 am »
Add this material to the diffuse slot or texture slot if using translucent material, use uv mapping type and scale to suit
Offline Skampus
« Reply #6 on: December 02, 2015, 06:24:08 am »
Hi Martin,
I should start thinking the simple way again :) Thank you, it works !!
Best
Markus
Offline mertmg
« Reply #7 on: December 13, 2015, 06:34:38 am »
thanks for the trick Martin
