Keyshot 6 vs Keyshot7 model position
Started by blueye89, September 14, 2017, 05:24:52 AM
blueye89
Hello to all,
I am wondering to know why this happened to my animation. If I open the same project animation (created in Keyshot 6) and also in Keyshot 7, the model has been moved to the left and little bit zoomed even if the settings of the camera are the same? In the attachment are both of the images to compare the problem.
Any help is very appreciated.
Danijel
blueye89
Still nothing about this software bug. Even in the version 7.1.36, bug is not solved and model is moved to the left. Camera settings and model position are the same cause I opened Keyshot 6 project in Keyshot 7.
Please download 7.1.51. We fixed some issues relative to cameras. Can you confirm that this is fixed?
designgestalt
hello Thomas,
how to do that?
the update check in Keyshot tells me, there is no new update available ( I have v7.1.36)
thanks
designgestalt
blueye89
Hello @thomasteger,
The problem still exist. I have downloaded and installed 7.1.51 but my model is still moved to the left as it is showed on the images above.
Do I need to report this bug in the section "Bugs and issues" ?
You should report this to support@luxion.com. Or you can send the scene directly to me and I will take a look. Use keyshot.wetransfer.com, and send to thomas@luxion.com.
Quote from: designgestalt on October 16, 2017, 02:20:17 AM
hello Thomas,
how to do that?
thanks
designgestalt
Check again. It should be live.
blueye89
Quote from: thomasteger on October 17, 2017, 12:00:19 PM
I respectfully request you keep the scene with models confidential.
Understood. Something is going on with the ZOOM animation. We will continue to investigate.
blueye89
Quote from: thomasteger on October 18, 2017, 02:38:29 PM
Thank you, Thomas. I am looking forward to your feedback.
Regards,
Danijel
