Author Topic: Render Ground Shadow Pass with Transparency  (Read 3217 times)
Offline Rollk1
« on: January 19, 2018, 05:14:47 pm »
New to Keyshot 7 and having an issue/brain fart with render passes. With Keyshot 6 I could render a PSD with the object, ground shadows and all other passes on dedicated layers. It was great. With Keyshot 7 when I do the same thing, I get the passes on dedicated layers as before but that shadows layer is on a white background, which is useless to me. Has this setting changed or am I doing something wrong?
Offline Will Gibbons
Re: Render Ground Shadow Pass with Transparency
« Reply #1 on: January 22, 2018, 07:24:41 am »
Passes in KS7 behave similar to how they do in many other programs for compositing purposes. Just set your blend mode to 'multiply' and you should be set.
Offline Rollk1
« Reply #2 on: January 22, 2018, 05:34:46 pm »
Forgot I used the clownpass to separate shadows to it's own layer  ;D
