Render Ground Shadow Pass with Transparency
Started by Rollk1, January 19, 2018, 05:14:47 PM
Rollk1
New to Keyshot 7 and having an issue/brain fart with render passes. With Keyshot 6 I could render a PSD with the object, ground shadows and all other passes on dedicated layers. It was great. With Keyshot 7 when I do the same thing, I get the passes on dedicated layers as before but that shadows layer is on a white background, which is useless to me. Has this setting changed or am I doing something wrong?
Will Gibbons
Quote from: Rollk1 on January 19, 2018, 05:14:47 PM
Passes in KS7 behave similar to how they do in many other programs for compositing purposes. Just set your blend mode to 'multiply' and you should be set.
Rollk1
Forgot I used the clownpass to separate shadows to it's own layer  ;D
